A1708 / EMC 2978 — Выпущенный в октябре 2016 года, этот MacBook Pro начального уровня сохраняет традиционные функциональные клавиши (в отличие от модели с сенсорной панелью OLED Touch Bar). Версия с функциональными клавишами оснащена процессором Intel Core i5 и двумя портами Thunderbolt 3.
Access to files on SSD drive.
Hi,
Can you please call me I’m looking for an adapter that allows me to plug in a 2016/2017 non touch bar SSD drive to either a USB-A or USB-C port to read and test drives externally.
I would need about 10 of them.
Apple Blade SSD 5GA 34+22 Pins NVMe
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Sorry we don't call people - To expensive!
Sadly your model uses a very different SSD connector as you can see in this Разборка MacBook Pro 13" с функциональными клавишами конца 2016 года jump down to Step 10.
So far no one has created one. Give OWC a call to see if they have anything thats the best I can offer you.
Your only option is to get access to another Fn MacBook Pro which you can swap out the SSD to gain access to your files.
Был ли этот ответ полезен?
Счет 2
Would installing my SSD into another working mackbook pro work exactly the same? meaning i would need the apple id and password from my SSD?
Счет 0
I don't have 10, I had 15 made and I think I have eight left, but I would be happy to send you my PCB file, and you can send it to PCB way like I did and they can make you as many as you want, I know the design works, I've been using it for years. I designed a custom PCB adapter several years ago and had PCB Way build several of them, specifically to recover data from 38+22-MacBook Pro SSDs. They're 38+22-pin to USB 3.2 Gen2x2, so quite fast, they get the job done.
Email me.
  • Jackson
  • PhixesPhones@gmail.com
Счет 0
1 Комментарий:
My above comment has the caveat of, as long as you know your password, then you're fine you can use my adapter just like any SSD to USB adapter
из Поделиться
Добавьте свой ответ
kirk буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 8
За последние 30 дней: 25
За все время: 2,394
