Четырехъядерный процессор Intel Core i7 с тактовой частотой 2,4 ГГц, 2,7 ГГц или 2,8 ГГц (Turbo Boost до 3,8 ГГц) и общим кэшем L3 объемом 6 МБ. Выпущен в феврале 2013 года.
Retina display is too dim
I recently purchased MacBook Pro 15" Retina Display Early 2013. I have owned a lot of MBP in the past but never a retina. I don’t know if it’s me but it seem like the brightness on the laptop is very dim. I reset the SMC, PRAM and also reinstalled the OS, nothing seem to make the screen any brighter. Before you ask, yes the brightness is at it’s max. Anyone have any suggestions or ideas on how would they fix this issues? A friend suggested to me that it could be screen that’s been replaced (refurbished display) I really would love to take advantage of the retina display experience. Can anyone please help me out here?
Это хороший вопрос?
Счет 2
1 Комментарий
Hello Daniel, wondering if you were able to fix your problem? Particularly if you changed the display out. I too have a MBP 15" 2013, and I get the impression the screen brightness is dim, even when maxed. However, I have read - in places- this impression is a tendency of the Retina display, especially in brightly lit surroundings.
из
Добавить комментарий
2 Ответов
Выбранное решение
If you have the tools, you need a p5 screwdriver to take off the back. Unplug the battery and reseat the display cable. You most likely need a new screen but that wouldn’t hurt to try, since you already tried SMC and the other obvious troubleshooting steps
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
I just tried your suggesting and no changes :( Thank your input and help.
из
Наиболее полезный ответ
I had this issue with my 2009 macbook pro, to where it was super dim even at full brightness and it did end up being the display, like it had to be replaced. I would def re check all the connections to see if any came loose, and if that doesnt fix it then a screen replacement may be required
Счет 1
2 Комментариев:
I checked all the connection and reseed them all. Still very dim. I think my next step is to in into a new display :(. Any ideas on where to look for one for a decent price? Buying it from Apple is very expensive.
из
I normally look at ebay, but the screens are quite expensive for the retinas
из
Добавьте свой ответ
Daniel Jenkins буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 4,693
