Руководства по ремонту и диагностике для Acer Aspire ES1-332. Этот бюджетный ноутбук построен на платформе Intel Apollo Lake и оснащен 13,3-дюймовым экраном.
acer logo loop and reset error
my laptop was stuck on a boot loop on the acer logo ive looked online and everyome mostly said to reset it but when i try to reset it it says error and ive tried to do the biomes boot thing aswell but i cant find it in the biomes.Idrk what to do someone please help
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Booting into BIOS can fix the problem because it allows you to boot from a Windows ISO image instead of the hard drive. You can then use the ISO image to perform a clean install.
What’s puzzling is that you said that your computer is stuck in a boot loop, and you tried to reset it but got an error message. But if it’s stuck in a boot loop, then it is impossible to reach the screen needed to reset it.
Is the issue that your computer is stuck in a loop of continuous restarts, or is the issue that your computer won’t let you reset it?
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
it keeps on showing acer over and iver again but when i try to reset it doesnt work
из Поделиться
In that case, please try the following:
1. Turn your computer on and start hitting the F11 button very rapidly over and over again.
2. If an "Advanced Options" screen appears, select the Startup Repair option. This will tell Windows to repair what is blocking Windows from loading onto your screen.
из Поделиться
Добавьте свой ответ
Fahim Ahmed буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 20
За все время: 2,306
