Razer Blade RZ09-0102 — это 14-дюймовый игровой ноутбук, выпущенный компанией Razer в 2013 году. Его также называют Razer Blade 2013.
Need a new screen
I need a new screen for a Razer - Blade 15.6" Gaming Laptop - Intel Core i7 - 16GB Memory - NVIDIA GeForce GTX 1060 - 512GB Solid State Drive - Black CNC Aluminum
Это хороший вопрос?
Счет 0
4 Комментариев
Thank you so much! I found one on eBay.
из
Hi have you disassembled the screen assembly yet? How do you do that?
из
I am curious too if you were able to disassemble it. I was able to get the bezel off the screen with a heat-gun to loosen up the adhesive, But from there its unclear how to get the lcd out, no screws. maybe its glued in?
из
follow up to my last post. The thin LCD screen is glued in and non-replaceable. Best option is to find someone selling a screen from a parted-out laptop on Ebay.
из
Добавить комментарий
1 ответ
Выбранное решение
vgould  you need to find a model number for your Razer Blade 15 to ensure you get the proper panel. Even better would be the label from your panel. that way you know for sure that they fit. Most common display for the standard model is the LGD05C0 display which is actually a LP156WFG-SPF2 panel. Do an online search with the model number to select a trusted seller of your liking.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
vgould буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 20
За все время: 1,564
