Tefal Actifry — конвекционная аэрофритюрница. Выпущенная в 2006 году, эта революционная и универсальная фритюрница позволяет экономично готовить широкий ассортимент блюд; кроме того, она безопаснее и проще в очистке, чем другие фритюрницы.
Actifry tefal error 6
I get error 6 after few minutes.
Update (01/10/21)
The problem was on the electric circuit .
I have replaced the capacitors and the problem has been resolved!!!!
Это хороший вопрос?
Счет 5
7 Комментариев
how to repair E5,E6 on fryer tefal
из
Check the HZ may be defrance then specific of machine 50 or 60
из
My actifryer squashes all the food up what would the problem be
из
Please can you advise how to change the capacitors as ours started throwing the err6 fault code today but after 6 or 7 times of it doing it every minute or so it stopped and worked fine again so i imagine its on its last legs or overheating maybe
из
Could you advise where you got the capacitors and how much they cost please
Thanks regards Martyn
из
Показать ещё 2 комментариев
Добавить комментарий
2 Ответов
Выбранное решение
There are two capacitors. Change both of them.
Был ли этот ответ полезен?
Счет 0
5 Комментариев:
Can u put pictures please
из
Where are they..? And what are they?
из
@Adrian Martin Take a look at the link in the second comment here by Eric B; there's a video and picture and places to buy the parts. It's in French, but that's what Google Translate is for.
из
I have got the same error. But the Black Actifry (model serie:025) does not have any capacitors, I discover... But I did get a third capacitor from the supplier, for free ;-)
из
I have replaced both the motor and thermostat and that did not help. I did not have the tool to check circut board but visually all looked fine. At least now after 10 times of disaassembky I know how to do it. I will check the capacitors again.
The official info about contacting electric supply company is absolutely out of the question. I have tried different networks and sockets.
Счет 0
6 Комментариев:
@Carlos Garcia quick question. do you have the error 6 on the actifry? Error 6 appears to be related to overheating of the 330nF capacitors on the circuit board. If you have this error post a couple of pictures of your circuit board so we can check things out.
из
Do you mean rhe gray capacitors
из
I have model IH7000 and it gave the same error... now it is OK
из
I am happy that I found a way to change the 334k capacitor & 100uf/35 capacitor error e6
из
Показать ещё 1 комментарий
Добавьте свой ответ
Dimitris Louvaris буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 17
За последние 30 дней: 95
За всё время: 29,650
