• Входные разъемы: док-коннектор iPod™ / стереоразъем 3,5 мм • Динамики: 2 высоко-/среднечастотных динамика Ridge™ и 2 низкочастотных динамика Atlas™ • Мощность усилителя: 2x15 Вт (ВЧ/СЧ), 2x30 Вт (НЧ) • Частотный диапазон: 40 Гц – 20 кГц • Входное сопротивление: >10 кОм • Питание: 8 батареек/аккумуляторов типа D, блок питания • Габариты (ДxШxВ): 500 мм x 230 мм x 240 мм
Standard vs. Rechargeable batteries
Hello,
My Harman Kardon go play 2 takes 8 D cell batteries. Each being 1.5 volts, that makes 12 volts of power. Rechargeable batteries operate at 1.2 volts giving me 9.6 volts. I've read that some electronics are sensitive to voltage changes like this and will fry while others are not. Is it safe to use rechargeable batteries in the Go play 2?
Thank you
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Hi Tyler media,
Well, I guess you can try, I think is a good investment.
For me, I do buy many rechargeable batteries, somehow for alkaline batteries, if left out for long time, the probability of leaking is high and the leaked chemical can damage terminals and seep into the circuit board, damaging it further.
You need to get a battery charger.
Some say Nitecore D4 is great, which I had one too
And perhaps AA to D cell converter / adapter
I had several batteries, ranging from Panasonic / Sanyo Eneloop and recently using Ikea Ladda battery.
I think if your side has ikea, you can consider it.
For this appliance I will recommend you to go for Eneloop pro series from Panasonic or Ikea Ladda 2450.
Link
https://www.panasonic.com/global/consume...
https://www.ikea.com/us/en/catalog/produ...
Interesting Reead
https://petapixel.com/2018/02/16/eneloop...
Был ли этот ответ полезен?
Счет 2
وواتننتن ادااا اهخخ ههههت تتتت تتت
Счет 0
Добавьте свой ответ
Tyler media буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 8
За последние 30 дней: 19
За все время: 1,672
