Issues Turning Computer On
Interesting issue.
Trying to take a look at a friend's laptop, it would turn on for a moment and immediately shut down. I decided to disconnect the battery, power cycle, and then turn it on using only the charger, which worked.
I then tried to plug the battery back in, with the charger aswell and it turned on just fine. I then took the charger out and it is back to square one.
The interesting thing is that even when the laptop dosen't have the battery plugged in, I have to power cycle it before it will turn on.
I also tried plugging the battery in WHILE the laptop was on, and then unplugged the charger, and to my surprise, it stayed on. But would not turn back on after a regular shut down.
My basic tech support skills have reached their limit, any ideas?
Это хороший вопрос?
Счет 0
1 Комментарий:
Bad PMIC? Maybe it just is broken, kr heat-damaged. Could also be a disconnected fan.
из
Добавить комментарий
