Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597вопросов Показать все
Replace fuses on one-wire circuit - but where are they?
I have obviously broken one or more of the fuses in the one wire cirquit to the magsafe on my Macbook Pro 15” mid 2012. There is a guide for replaceing these on a 2009 model, but the T1 and T2 fuses are not located in the same spot on the 2012 model. Is there some guide or image displaying the location?
And where can I get those fuses - MOSFETs?
Это хороший вопрос?
Оценка 0
1 Комментарий:
@hallbir post some good pictures of the components that you believe are obviously broken. Post those and the location on the board with your question. That way we can see what you see. T1 and T2 will not be fuses.
Adding images to an existing question
из
Добавить комментарий
2 Ответов
Reference with the logic board model number and not the model of the MacBook, the number will be 820-3330 for your model and the label is located generally at the bottom right of the board (top-side).
Check boardview and schematics for 820-3330 which you can find on the internet.
On the MagSafe DC Power Jack circuit (also known as one-wire circuit) there is a component that commonly gets blown from the use of knock-off (aftermarket) chargers which is U6900. Replacing the chip will fix the problem if that is the case.
U6900 is north-west of the keyboard connector as seen here:
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
@benjamen50 Lets table this as I suspect he's just throwing things out.
из
Good point, as in most cases replacing fuses may just lead to them blowing up again if there is a short circuit present on either pads on where the fuse sits.
из
There is only one Fuse on the power leg of the MagSafe connection on the logic board. There is no fuse(s) in the One-Wire sense line. The connection goes directly to U6900 for over voltage protection of the charging of the battery.
Let’s start again what are your symptoms with your system?
Review the MagSafe connector on your charger as well as the cord if either or worn or damages this could burn out some of the components on your logic board.
Оценка 0
Добавьте свой ответ
Hallvard Birkeland будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 234
