Lenovo G50-80 — это персональный ноутбук начального уровня, выпущенный Lenovo в 2009 году. Ноутбук оснащен 15,6-дюймовым экраном и работает на базе графического процессора Intel.
OneKey Recovery/ HDD upgrade to SSD
Hi, I had this laptop for almost 3 years now and I have been looking for an upgrade I got a 480gb SSD I copied all my data from the old HDD to the SSD using a software but once I replaced them and tried to boot the OneKey recovery would pop up and non of the opinion initial backup nor the user backup work.
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
What was the size of the original drive. I don’t recommend this software. You should have bought [связанный продукт отсутствует или отключен: IF107-131] and used this https://www.macrium.com/reflectfree . I never had issues with macrium.
Был ли этот ответ полезен?
Счет 0
11 Комментариев:
The original drive is a 1TB HDD, and I did use the macrium reflect 7 for copying the data I wanted to use the SSD as a boot drive and the HDD as external I already have hard drive enclosure with USB 3.0
из
The only problem I get is with the OneKey Recovery I searched online and couldn’t find a way of bypassing it or disabling it
из
I think not all your files fitted in. You should have bought bigger drive. How much free space did the original have?
из
About 600GB was free
из
After transferring all my files there was about 70GB free left on the SSD
из
Показать ещё 6 комментариев
Добавьте свой ответ
Nedzhati буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 1,614
