Дата выпуска: 26 октября 2018 г. Модели A1984, A2105, A2106, A2108. Доступен в версиях GSM или CDMA / eSIM, nano-SIM или dual-SIM / 64, 128 или 256 ГБ / черный, белый, синий, желтый, коралловый или красный цвета. (Произносится как «Айфон 10 эр».)
How to replace : iPhone XR Rear Camera Lens Cover
Will heat release the glue of the. Lenses COVER.? I bought the lense cover but I can not find anything as to how to remove just cover by itself!?, anyone have a step by step guide or a video that you have discovered?
Thank you,
papa
Это хороший вопрос?
Счет 4
1 Комментарий
I used a paper plate cut a hole out the size of the rear lense and used the tip of a regular iron and kept the body of the iron away from the phone! Once it was on for about 5 seconds I used a single edge razor blade to remove small bits of glass from the ring. I immediately vacuumed any debris from the phone or the paper plate i had below the phone!
2 paper plates, iron ( no steam ) alcohol to clean camera, vacuum cleaner, jewelers glasses, white light!
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
The glass is stuck on there really good and just heat will not help much. The glass will just keep breaking while you remove it and some will get inside. The best way to do this is by taking apart the phone and removing the camera to be able to prevent it from getting damage. You can also try using a small tip vacuum cleaner right at the camera while prying out the glass bit by bit while keeping it warm so it doesn’t end up falling in the camera.
Был ли этот ответ полезен?
Счет 1
Did anyone ever answer this? I also got a lens with cover when ordering the part.
can I remove the lens housing from the Backglass without cracking the back?
Счет 0
I bought a Replacement lense with the iron ring around it.. how can i replace that?
Счет 0
1 Комментарий:
The problem is i bought the full lens with metall ring…
из
I replaced the lens without taking the phone apart.
Somewhere someone recommended using a utility knife and carefully breaking the lens out piece by piece.
I did that with a utility knife and finished up with an X-acto knife. It worked fine for me.
Счет 0
Добавьте свой ответ
Get Up & Go Now буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 19
За всё время: 15,096
