Смартфон Motorola Moto Z3 Play был выпущен в июне 2018 года. Он оснащен 6-дюймовым экраном и несъемным литий-ионным аккумулятором емкостью 3000 мАч. Разрешение задней камеры составляет 12 Мп, фронтальной — 8 Мп. Номера моделей: XT1929-3, XT1929-4 и XT1929-8. "XT1929-3 NA XT1929-4 NA XT1929-4 NA XT1929-5 LATAM XT1929-6 LATAM XT1929-8 EMEA/APAC"
Screen replacement causes digitizer to not work
We are a repair shop and we have tried replacing the screens on this model a few times xt1929-17 and every time the digitizer doesn’t respond on the new lcd has anyone experienced this issue or come up with a fix?
Это хороший вопрос?
Счет 10
Добавить комментарий
2 Ответов
I am also experiencing this issue! The digitizer stops responding once you turn the phone off and then back on… it’s a little annoying to say the least. Any guidance on this would be awesome!
Thanks
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
I’ve researched and asked local shops as well most have just blamed it on the current quality of the parts on the market being low. Are shop has suspended repairs at the time do to the large warranty rate of the XT models
из
You have to do a hard restart. It’s the only way I’ve found to do it.
Счет 0
2 Комментариев:
Could you clarify how you did that? I had the battery cable disconnected, replaced the screen with no problem, and turned the phone on without issue. The problem is that the touch doesn't register, no matter how many times I fiddle with the battery. This was a straightforward, easy fix up until this point.
из
When he says hard reset, he's likely referring to a factory reset.
I haven't replaced the screen on this device yet, but I plan to soon. I'll let you know if I run into this issue and have I might fix it.
из
Добавьте свой ответ
Mike Henry буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 1,315
