How can I replace button switches?
My switch on the right click button got broken. I can’t find a replacement on any site. How can I buy one?
Это хороший вопрос?
Это хороший вопрос?
Omron - D2F-01F (Japan), D2FC-F-K(50M)-RZ, D2FC-F-7M (20M), D2FC-F-K (50M)
I just replaced my switches with Omron - D2F-01F (Japan).
Those switch models are global numbers and easily searchable.
Kailh GM Red
Huano Micro Switches
TTC Gold.
Each of these manufactures also makes switches that work as substitutes but have a different tactile feel and actuation pressures.
Был ли этот ответ полезен?
Any ideas what model is the middle switch?
Yeah any idea what the middle mouse switch is? it seems to be 1 mm shorter than the stock standard middle mouse switch.
I know this thread is old but I have a Deathadder Chroma and I successfully replaced the middle mouse switch with E-Switch part number TL1150AF070Q. I'm sure any switch of similar dimensions would get the job done, just make sure the actuation force is practical for your fingers. https://www.mouser.com/ProductDetail/E-S...
About D2F-01F - it is ok, but not for too long. I replace mine with this maybe 1,5 a year ago and now it makes double clicks again, maybe 2 times for 50 clicks, but still annoying at work. Glad I bough some DeathAdder just in case and another switch, so I will use DeathAdder in the meantime when I find some time to solder the new switch :)
You can use an old mouse switch it’s the same.
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 51
За все время: 4,563
