Kilburn no sound from speaker
Hi i have a Kilburn speaker purchased about a year ago and it stopped working there is no sound coming out it powers up connects to bluetooth everything i tried with the 3.5 mm cable and is the same no sound at all. When i switch the input sources from bluetooth to 3.5 mm it make a noise
Update (08/03/2019)
. I took it apart an everything looks good nothin burned etc I’m not sure where is the ic I’m guessing is in the top right cornem with heatsink on it
I replaced this and nothing changed I attached a picture
Это хороший вопрос?
Счет 1
16 Комментариев
That would be the area of interest. Any chance we can get a couple of good picture from that side?
из
Added some pictures and a short clip let me know what you think.
из
Sounds like it's getting power somewhere and than it croaks. I know I am asking an awful lot here but is there any chance you can see if there are any numbers on the IC's. The one with the heatsink. the one right to it and then there is a eight legged one soldered to the board (U1). That might help us to determine what they are and how to check those out. U1 looks like something is up with it.....
Of course schematics are really hard to find for something like this.
из
and the one on the right is D669AC don`t worry about asking to much i`m happy that somebody is trying to help me. added 2 more pictures of the IC`s
из
D669AC is your audio amplifier. D669AC also has an NTE Equivalent NTE373 NPN audio amplifier transistor. So now off to find a datasheet and hopefully we can find a way to test it out. Prices for it are low enough that one could even go ahead and change it without testing ;-)
из
Показать ещё 11 комментариев
Добавить комментарий
7 Ответов
Наиболее полезный ответ
WARNING: VERY LONG POST
One of my coworkers asked me the other day if I could take a look at his Marshall Kilburn speaker to figure out why there’s no audio coming out at all. The speaker would charge the battery, turn on, select the source input and even connect to bluetooth, but absolutely no audio playback whether connected with audio cable or bluetooth.
The speaker was not exposed to the elements, it simply decided one day when he turned it on to not play any audio.
''I disconnected the AC power and the battery'' and opened up the unit to inspect the board for obvious signs: burnt components, dislodged connectors etc., but found nothing unusual.
I had a hunch that something went wrong on the audio part of the board, but being unable to find the schematic, I started with the data sheet of its audio “brain” - U10. This chip is NTP8230 and you can get the data sheet here:
http://www.zpxic.com/manual/NTP8230_icpd...[1].pdf
This was enough to get me started on checking the voltages ( I reconnected the battery ONLY), which turned out to be ALL correct and again no signs of damaged components.
I disconnected all the connectors and removed the board from the metal back plate to be able to have a closer look under the microscope. This was the EUREKA moment. While the normal inspection could find anything wrong, a closer look found tiny traces of corrosion in certain spots on the board-see pics below:
Since the resistor R95 looked quite corroded, I started poking around (literally) the black compound covering the other half of it.
I have manufactured my own tool for the job: soldered a sewing needle to an old multimeter probe. As I was poking the black resin, I could see some oily liquid seeping from underneath. As I EXTREMELY gently poked and picked chunks of black resin, I had the deja-vu moment.
This was the BREAKTHROUGH !
Just when we thought the bad caps nightmare that plagued the industry for more than a decade was over, the curse of the leaky caps strikes again. Now the culprits are the cheap CHENGX electrolytic caps used on this high end (?) speaker. The electronics companies never really learned the lesson ?
It has become very obvious what I was dealing with: corrosion damage incurred by the electrolyte leaked from the caps and nicely concealed by the black compound surrounding various components.
From this point on, you are about to embark on a long and tedious journey and I cannot emphasize enough about how gentle and careful you have to poke and pick the compound to expose all the affected areas , without damaging traces and the surface mount components hidden under the compound.
Do not cut corners ! After all, cutting corners created this mess in the first place: clear nicely all the affected areas.
The area around the AC input was not affected ( no caps) and didn’t need to remove the compound.
The next step was to neutralize the corrosive liquid and clean up the mess. I always had the best results with de-ionized (or distilled) water to clean the corrosion and the residue. Use a little semi-stiff artist brush for local clean-up, DO NOT submerge the board! Once you are happy with the outcome, finish the cleaning job with 98% IPA (isoprop alcohol). This one you should apply freely making sure it penetrates under the big components as well. You can do this twice if you feel like it. Th IPA will remove other residue and most importantly will remove the de-ionized water used before. Let the board dry nicely and at that point you can start assessing the damage incurred by the corrosion.
In my case, the resistors R95 and R97 suffered the most damage:
R95 was completely corroded and came off, R97 looked a bit better but still had to be replaced. Luckily enough the pads were still ok, once I scraped off the oxide. Luckily I had exact replacements for the two 100 Ohms resistors and these are the results:
So, were these two the root cause of my initial issue?
Short answer: YES !
Long answer: both resistors were open circuit. Tracing the pads I found them leading to our audio ic U10, pins 8 and 9. Looking at the NTP8230 data sheet, pins 8 and 9 are SDA and SCL. Now it all make sense ! These 2 pins are the i2c communication lines with the rest of the board and they were disconnected (open). Our beloved audio chip is in i2c slave mode and although it was powered on, it couldn’t talk to the master. So it would just sit there, not knowing what to do. Hence no audio output !
Reconnected all (except for AC power) and gave it a try. Wow, I soon understood why my coworker wanted this puppy repaired. The sweet sound coming out of this speaker was the prize of my hard labour :)
Sooo, is the repair done ?
Yes and no.
Well, the leaking crappy caps became crappier and they will probably leak some more or dry out completely. In order to properly finalize the repair, all the electrolytic caps should be replaced with proper ones and reapply some compound (RTV maybe?) to prevent vibration damage ( it is a speaker enclosure, remember?).
Luckily, digikey and mouser offer a very good choice of quality caps (Nichicon, Panasonic, ChemiCon) which will not break the bank either. Totally worth it (20-30 bucks total). All you have to do is to cross reference the original cap specs to make sure you get the correct replacement caps.
CHENGX provides a spec table for their caps which is not the best technical sheet but it is better than nothing:
http://www.bentex.com.hk/catalog/capacit...
Now, it would be REALLY nice if any expert out there would pitch in and provide a tested and proven direct replacement info for the caps replacement.
It is time for me to move on to other projects, but I will still be lurking around for a while in case you have any questions regarding the above.
Good luck everyone and happy fixing !
Был ли этот ответ полезен?
Счет 5
5 Комментариев:
I think I have the same issue, on the same transistors. But I lack the skills to fix it :-|
из
Could you provide the links where we can buy the replacements caps? Is it the same CHENGX page you linked? Where could I buy the resistors replacement? I'm planning on trying this, seems to me I have the exact same issue.
из
I can’t thank you enough for your detailed guide.
I had the exact same problem with the R95 resistor in my Marshall Kilburn MK1 (Although I am not sure if electrolyte leaked from the caps as you mentioned. The caps look okay-ish… But yes the resistors were both corroded)
I carefully removed the thick black stuff.
A friend of mine then helped me replace both R95 and R97 resistors with 100 Ohm 0603 SMDs and tadaa everything’s working fine as before.
Thank you very much @io nut
из
I have similar problem with my Kilburn 1, at the beginning it won`t play any music from BT or cable, but after some time ( no rule, somewhere between 15mins and 1 hour) it starts making popping sound when changing source or changing where to send music on the phone and this is a signal that soon will start working. And after couple of minutes starts playing music normally, from both, cable and BT. Next time when you turn on speaker for first time after a day or two or whatever, again same... I`m a having the same issue with capacitors and R95 R97...?
из
So glad I found this guide! My capacitors are all fine and a different brand, as I own the revision "B" board, but the symptoms we're the same: noch audio. What helped was pointing to the audio chip! I poked around with my probes and accidentially found a shorted 100nF SMD capacitor, pulling DVDD to ground.
Replaced it, now speaker plays fine again!!
из
Attila Fustos  time to take it apart and check the amp board. Look for charred components etc. Possibly an amp IC that has failed but we’d need to see more of the board etc. Добавление изображений к существующему вопросу
Счет 1
1 Комментарий:
Ihave the same problem too.No sound comes out.shitch on ,blutooth connect and line in vry ok.but No audio out.
Where can we get the D669AC and NTE373NPN around kenya
из
may be LL10 is open , on the solder site off the printboard ; i had the same fault
Счет 0
2 Комментариев:
Hello, have you found the characteristics of the LL10 inductor? Thank you
из
LL 10 = 2,7 uH
из
If you don’t have a leak like io nut showed above (I didn’t after 5 years of use), try to reset the speaker. Switch speaker off. Push Source and Pair buttons at once, switch speaker on and hold buttons for 10 sec and than release. Switch speaker off and on and try. This worked for me. It should work on battery or on mains. I had to do it 2x but now it works. Hope it helps.
Счет 0
1 Комментарий:
Hello, I currently am facing this problem. I've owned this speaker since 2015 and never had this problem. Contacted support and they basically told me that the BT needs to be reset. To do that I need to "delete" the device from my phones BT devices (like the comment below suggests). It worked for a day but now I have the same problem.
I will try your process to see if it works for me but I have a question.
When you say hold the buttons for 10 sec , do you mean hold "source and pair" buttons for 10s at the same time?
из
In my case, I heard only low noise when I started playing sth via BT.
I had to delete the Kilburn from the iPhone BT list(ignore this device).
After reconnection: The problem was gone
Счет 0
There are the capacitors
Счет 0
3 Комментариев:
@albertoyeguez the top two on the right hand side are 470µF 25V capacitors.
из
Do you know the values of another one? Theyre green capacitors
из
Hello, I also have a similar problem with the sound of this speaker when I opened it. I realized that it had about four electrolytic capacitors damaged, so they were exploited. I would like to know if anyone can send me a photo of those four electrolytic capacitors, please.
из
appriciate it's a very old topic but in case anyone perseveres with glitchy Kilbunr v1 ... I had problems with main power supply which was due to one of the rectifier diods described and resolved here
the speaker worked for a about a week then stopped responding to Bluetooth or aux inputs - no music from the speaker, only static noise and cracking sounds similar to Atilla's video.
I could not find any signs of corrosion but there were few tiny yellow droplets in the proximity of the capacitors. Fiddled a bit with cleaning but no luck. Eventually, after switching between AUX and Bluetooth the music (almost magically) reappeared. Statick noise and cracking sound on Bluetooth remained and from time to time it stops playing. I switch between AUX and Bluetooth few times , after that the music comes back. I've no idea what that could be - there are no obvious signs of damage on the board.
Wonder if anyone may have an insight or an advice to share. I've been fixing this speaker for a few years now - it's way beyond it's economic value but turned into a hobby sort of :)
Счет 0
Добавьте свой ответ
Attila Fustos буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 32
За последние 30 дней: 143
За всё время: 18,459
