OnePlus 6T — это смартфон на базе Android, созданный компанией OnePlus. Он был анонсирован 29 октября 2018 года и выпущен 6 ноября 2018 года.
Volume button got dented in
I sent my phone out for repair but they are saying the LCD assembly got damaged as well, is that possible for a small dent on the volume button to cause that damage?
Это хороший вопрос?
Счет 0
Добавить комментарий
5 Ответов
is the volume button near any support or construction of the phone? Maybe they meant that the button cannot seat properly but I am not too sure.
Sorry I do not understand what you are asking
Could you expand please
Был ли этот ответ полезен?
Счет 0
Volume been dented in may be beacause the push connector on the inside which is on a cable maybe damaged
Is there damage to the frame of the phone by the Volume button
Счет 0
1 Комментарий:
Hi Jerry! Okay, the volume button was dented in with the frame of the phone rendering the button unpressable. I am not sure about the construction of the phone or anything that has to do with the internals of the phone but all I know is that the frame and the volume button are fused together.
из Поделиться
The volume button and the frame are not fused together
Счет 0
1 Комментарий:
Yes, I understand that but do you think I can remove the volume button from the phone and bend it back into place. Then after I do that, I can sand the frame of the phone just a bit so that the volume button can move back and forth.
из Поделиться
If the main frame is bent . The best think to do is to get a new casing and transfter everythink over to it
If it working fine why not leave thinks has they are
Счет 0
1 Комментарий:
Yeah I might do that but the whole frame costs 140 dollars and this is just to repair the volume button. Is there any way I can just repair the volume button itself?
из Поделиться
Full frame with all buttons
https://www.ebay.ie/itm/173463031607
Счет 0
Добавьте свой ответ
WARBUSCUS буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 11
За последние 30 дней: 25
За все время: 669
