Представленный в августе 2017 года, Galaxy Note8 стал преемником отозванного Galaxy Note7. Смартфон поступил в открытую продажу в сентябре 2017 года.
Device will not power on
My Device will not power on.
Powerbutton stopped working, I did not care, but when the screen fractured I send it for repair, the workshop manage to change screen and start the phone witout powerbutton. but then it went out of battery. I charged it fully. It did not boot automatically.
I wnt to several workshops they did not manage to start my device. There ar to capacitors located on motherboard near powerbutton. these capacitors / resistors have decomposed due to water damage.
When I charge, display shows battery status.
when I try to boot in to download mode it wil not engage download mode.
  1. is it possible to replace these components without replacing motherboard ?
  2. Where can I by these components ?
  3. Is there any other way to boot samsung galaxy note 8 without power button ?
# Is there any way to extract data from device ?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Do you have any skill when it comes to soldering? its not easy to solder on new connectors but its possible.
Also have you tried just getting the corrosion removed with some cleaning alcohol ? You might be able to clean them up enough so that the button will start to work again.
Try to plug the phone to a power source and hold the volume down button. In the boot menu you can choose to restart it which should turn it back on.
hope this helps
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Iftikhar Mahmood буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 4
За последние 30 дней: 33
За все время: 239
