Dell Inspiron 3179 — это ноутбук-трансформер 2-в-1 из серии Dell Inspiron 11 3000. Это легкий, удобный для переноски и относительно недорогой ноутбук, доступный в четырех цветовых вариантах.
Hdd data interposed installation.
Hi, I bought an Inspiron 3180 and it has 32gb emmc storage. Upon upgrading the ram I noticed soldering points for an interposer labeled HDD1, must have used the same motherboard as models with hard drives. I was wondering if there is a part out there that I can solder an interposer connector to install a 2.5 in. SSD? There's enough space in the chassis for a hard drive. I could affix it with tape. Was wondering if this sort of project is possible and if so what part would I need, I'm having trouble finding one and Dell hasn't been much help. Helpful but not completely. Thanks for the read.
Update (08/10/2019)
I’m not sure how the posting of pictures works, I hope these pictures help in answering my question. It appears that an interposer connector could be put in but I cant find the part from Dell.
Это хороший вопрос?
Счет 0
1 Комментарий
@dchar2189 post some good pictures with your question. that way we can see what you see. Yes, it is possible that this would work. Just a matter of trying to find out what exact number your motherboard is
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
@dchar2189 sure looks like all you need to do is to solder a connector to that area. Issues that could arise from that is that we do not know what connection goes where and hopefully everyone adhered to the standard.
Check something like this connector, you may have to bend the piece on the ends up to fit your board. D:\DocManager\Check In\Vincent\ECR-10-004449\2023246-c SH1-A3 (1). from what we can see on your picture and checking the dimensions, it may just fit. Check this connector as well as this one which would be great since it is a slimline version. I see no reason why not to try it.
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
It looks to be exactly what I'm looking for having some trouble ordering it though, will keep you posted.
из Поделиться
@dchar2189 please do. Would love to hear how it turns out. BTW welcome to iFixit.
из Поделиться
Добавьте свой ответ
David Charette буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 10
За последние 30 дней: 23
За все время: 417
