a7R II (номер модели ILCE‑7RM2) — это выпущенная в 2015 году полнокадровая беззеркальная камера Sony со сменными объективами.
Menu scrolling through itself like crazy
My Sony A7S Mark 2 is moving the menu by it self please how do I fix this?
Это хороший вопрос?
Счет 0
5 Комментариев
hi, i have the same problem with my Sony A7ii. Menus switching on its own and sometimes goes back to normal then switching and scrolls again.
Did you already FIX yours??
Thank you :)
из
Same problem. Any help?
из
Me too. Anyone sort it?
из
Very late reply. Got mine fixed at the nearest camera repair shop for USD65.
They say this is a common problem with Sony A7II after sometime...
из
Hi. Did they say what the problem was that fixed the camera? 65$ is pretty affordable. Thanks
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hey, Shakily_17
The issue could be that you need to replace the buttons, but it's likely that a ribbon cable isn't fully connected or it is damaged. This issue can be found in other devices such as the Sony Dualshock 3 and the Asus Zenbook.
Был ли этот ответ полезен?
Счет 2
Sounds like a "Stuck Button" Problem. Common with most devices that you use the buttons, when they aren't cleaned they can stick. Even if the "External Buttons", or the button layovers, are cleaned, the internal buttons may be dirty. Try cleaning the buttons with Isopropyl Alcohol, and a soft electronics towel. If that doesn't work, check the cables and clean the internal buttons and cables if necessary.
Счет 1
Добавьте свой ответ
shaikly_17 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 49
За все время: 1,736
