Многофункциональное устройство HP Officejet Pro 8600 Plus можно определить по номеру модели: N911g. Этот принтер, выпущенный в 2011 году, отличается коричневой расцветкой и сенсорной панелью управления.
What is a printer failure?
It said “printer failure,” but I don’t know what happened that caused it. It said,
Printer Failure
There is a problem with the printer or ink system. Turn printer off, then on. If problem persists, contact HP.
Then I took pictures:
Это хороший вопрос?
Счет 0
1 Комментарий:
Evan, have you received any offline replies? I have this exact issue with my OfficeJet Pro 8600 Plus, using my Mac that's running OS X 10.14.4. I've done all of the suggested troubleshooting too, and now I can't even run the HP EasyStart app to check if the firmware is up-to-date b/c even tho the wifi icon is lit up on the display, EasyStart can't find the printer on my network. And I can't get beyond the "printer failure" message on the display...!
из Поделиться
Добавить комментарий
1 ответ
Sure looks fine internally.
Have you tried the troubleshooting steps on HP’s support site? My gut tells me there might be paper stuck in the duplexer. I’ve had that same model printer and it seemed like it was getting choked with paper constantly.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Evan Lei буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 27
За все время: 1,621
