Samsung B1445A — это высокоэффективная стиральная машина с фронтальной загрузкой от компании Samsung.
Washing machine is unblanaced
My washing was doing fine until I overloaded it. It makes a load banging noise now. I turned the drum inside and as it turns 360 it makes a clunk noise and feels like it jumps out and back in again on the turn. I hope that makes sense. It makes a loud noise when it washes and spins since i overloaded it.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
There is a filter on the drain line. If the filter is clogged, the water does not drain properly and the result is a terribly unbalanced tub. The machine will literally walk across the room. Look down low for the filter. Maybe behind the front lower panel. Or get owner’s manual to locate it.
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
If not the filter, there might be a broken roller, but that is not so common. Does the tub look like it's in the proper place? Does water leak out the door? That type washer is usually capable of a big load. If the tub rollers are broken or out of place, water will leak out the door.
из
I have the machine on now. I haven't put any washing in but it's still making a noise I can't explain the noise.yes water is coming out of the door
из
I have the machine on now. I haven't put any washing in but it's still making a noise I can't explain the noise.yes water is coming out of the door. It definitely title sounds like the roller is out or something. Maybe even broken.
из
Добавьте свой ответ
Marama Davis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 22
За все время: 650
