Sixth generation of the iPad, released in March 2018. Available in Wi-Fi and LTE with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
Вопросов 20 Показать все
red And blue colors showing up
I recently got the iPad 6, when it fell I picked it up and it looked fine but I can see red and blue lights whenever it is showing a black screen or dimmer apps. Is there a workaround from getting a new iPad or taking it to get repaired?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (3)
Выбранное решение
The pixels in the actual LCD coulv’ve been damaged from the shock of being dropped. So a new LCD would fix this.
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
Try to “smack” the back of the iPad a couple times to adjust the LCD connection. If this does not work, it may be some type of LCD damage. The replacement process isn’t all that bad or expensive so that is still an option if necessary.
If you recently bought this device new from apple, you should exchange it for a replacement one.
Оценка 1
you should take it and get a new one because it cost more to repair it than to just get a new one
Оценка 0
Добавьте свой ответ
maxypaxy10019 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 251
