Motorola Moto E4 Plus — также известный как XT1774, XT1775, XT1776 или Moto E 4-го поколения — оснащен большим 5,5-дюймовым HD-дисплеем и имеет гладкий металлический корпус. Устройство оборудовано аккумулятором емкостью 5000 мА·ч, водоотталкивающим покрытием и сканером отпечатков пальцев.
4G data not working
I’ve had my Moto E4 Plus for almost two years now and it’s been fine, but about two months ago my 4G data stopped working. It’s not like I have 3G all the time and just can’t connect to 4G, I just only have an internet connection when it is weak. For example, I can be downtown in a city and have nothing, but in the middle of the woods I’ll have a weak connection.
I’ve looked through my settings to see if there is anything that I may have pressed unknowingly, but after resetting to all of my original settings it is still a problem. I’ve also went into safety mode to see if an app I downloaded was blocking it, but that didn’t help either.
Does anyone know what could be wrong, and possibly a solution?
Это хороший вопрос?
Счет 0
1 Комментарий
I have motorola noto e4,my cousin brought it from karachi ,he told me that it was connected to4g networks in Pakistan ,or simpky karachi ,but when he brought it kashmir, it stopped connecting to 4g network on every network sim ,there are many motorola phone which only connect 4g in pakistan,not in kashmir,kindly someone help ,me... Please
из Поделиться
Добавить комментарий
3 Ответов
Наиболее полезный ответ
My device is not 4g working
My device 4G not working
Был ли этот ответ полезен?
Счет 1
IT IS JUST A PERSONAL EXPERIENCE — I was having the similar issue with a Customer after screen replacement, and after check Settings and a Factory Reset the problem persists. Opening the phone i saw one of 2 antennas was disconnected, put it in back fixed the issue.
can be something disconnected inside, a software issue and maybe is your carrier, a call can answer it, may they lower your data plan or something like that.
Счет 0
2 Комментариев:
Thank you for answering! I don't believe it is a carrier issue, my phone had to switch over to Boost Mobile since Sprint Forward no longer exists, and switching didn't solve the problem. Do you know if there is a way I can check to see if an antenna is disconnected on my own, or do you think I should bring it somewhere to be looked at?
из Поделиться
If you dont feel comfortable taking apart your phone, a place named genius phone repair does free diagnostics for any issue
из Поделиться
my netwok is notgoing
Счет 0
Добавьте свой ответ
Sarah буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 18
За все время: 2,362
