В августе 2000 года в Японии была представлена девятая генерация Corolla с более острым дизайном и новыми технологиями, которые позволили этой модели войти в XXI век.
Reverse wire / Backup wire?
I am installing a backup camera and new radio in my 2006 Toyota Corolla. I have everything wired except for the reverse / backup light wire. I have found the wiring harnesses to the left of the clutch. Can you help me identify the correct harness and wire for the reverse /backup light?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
@syb tapping into the wiring harness sounds to complicated and cumbersome. Go for either the backup light switch, a junction connector or even the fuse box. Looks like the backup light is fused by itself.
The back-up light switch is located on top of trans, rear towards the firewall,The Fuse located in the under hood fuse/relay box. Take a test light and with key turned to the on position. Ground the clip end of the test light and use the pointed end to touch each wire connector. One wire on the switch should be hot (B+ test light turns on), this means you have voltage to the switch. Then with the wires connected to the switch, put trans in reverse. With key in the on position test the other wire which will also become hot (B+ test light turns on). That wire would be a good candidate to tap into it for your backup camera.
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
Sue Anderson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 13
За последние 30 дней: 47
За все время: 5,348
