Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
Dim screen Not 6r8?
I have a 3gs with a dim screen so i figured 6r8 coil i have done 2 before so i knew the symptoms. I replaced it and it still has dim screen i even tryed a different coil and still dim screened what else could it be?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
3GS backlight issues seem to be caused by Display LCD, 6R8 coil, or IC 109B. If your LCD Display is good, then hopefully it is the 109B chip. This chip is right next to the coil.
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
I used one off a junk board and when I went to take the chip off my good board i pulled off one of the two pads underneath!!! Is my board junk now??
из
Can anyone help me?
из
Jared check on this Anyway to reattach solder pads? and click on the link provided by ABCellars. Little bit more on the repairs possible right here http://home.comcast.net/~machrone/bjr/mi... but definitely not as neat. Good Luck
из
I think you need to comfirm your 6r8 is original, since many seller online sell 6r8,but a little bit difference with the one on the 3GS motherboard
I check a site ,the picture is same as on 3GS motherboard, and I get the items from them, it is original and can work
here is the link
http://wiisingonline.com/iPhone-3GS-6r8-...
Счет 0
Добавьте свой ответ
Jared буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 3,578
