Смартфон Alcatel One Touch Idol 3 оснащен 5,5-дюймовым дисплеем с разрешением 1080 x 1920 и работает на базе процессора с частотой 1,5 ГГц. Выпущен в июне 2015 года. Модели: 6045Y, 6045K, 6045O, 6045I.
Text but not call out.
The signal strength in my area is not strong enough to make calls. The phone works fine when a decent signal is present. I’m OK with this for now since I have a landline. I can, however, send texts when I’m in this low signal area. How is it I can send texts but not make a call?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
[ SMS is a standardized communication protocol that enables devices to exchange short text messages and was defined as part of the 1985 GSM protocol. Originally it was designed to "fit in between" existing signalling protocols which is why SMS length is limited to 160 seven-bit characters. It was subsequently codified into the SMPP signalling protocol that transmits SMS and is limited to precisely 140 bytes (or 1120 bits). ]
You need less that a second of stable signal to send one SMS, but one call needs a stable connection to start a session.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Thank you...
из
Добавьте свой ответ
ruko буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 170
