Руководства по ремонту и информация по разборке Mac Pro четвертого поколения, выпущенного в декабре 2019 года.
Boot RAID installation question
Given the difficulty with user installation of SSDs are there best practices for SSD installation if I want to run a boot RAID? Can I run a boot RAID on this machine? I have been running one on my mid-2010 MacPro, which clocks access times faster than the new machines. Would it be best to install as a PCIe card?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Why? Keep in mind the T2 flash drive array is much faster than a SATA or even the PCIe RAID set even with SATA SSD’s!
The ideal setup is to get as large of base storage (T2 flash) you can hopefully 1 TB. Setup your MacOS and apps on it (typical setup) leave the rest of the drive empty! Now setup your SATA RAID either internally or externally as your data volume keeping your projects on it.
Also remember this system is designed for heavy pro’s in mind. Video & Music creation being the top two. Others which will likely use this system is animation work and very deep graphics designers. While photographers will also likely use it their need is a bit different as its the XDR display which is paramount! As the color correction is important when working on a series of images that need to match up. So the low end model will likely meet their needs and lots of RAM.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thanks, Dan. You are correct --I was misreading the access speeds. I'm a video guy, so I want something I can upgrade as working resolutions increase.
из Поделиться
Добавьте свой ответ
William Danton буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 3
За последние 30 дней: 13
За все время: 1,196
