Asus K53E-BBR3 — стильный 15,6-дюймовый металлический ноутбук для повседневного использования, выпущенный в 2011 году.
DC power jack loose
Can anyone helpme, this just occured today. When i was charging my laptop it suddenly not charging so i push and it work only if i pushed it. After searching on the internet it says that my laptop dc jack has come loose, can anyone help what should i do with this.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
If the power jack has come loose, you need a soldering iron to reattach it to the motherboard. It needs to be a good one, the cheap ones don’t get a good enough temperature to get rid of the old solder. If the power jack itself is damaged, you can usually buy a replacement power jack online with the correct make and model number of the laptop.
If you’re not that good with a soldering iron, or don’t have one, then you can disassemble the laptop and take the motherboard and power jack to a computer repair shop and they should be able to do it. Most of the time is taken up by the disassembly as it can be a bit persnickety, but instructions are available online and on YouYube for many different models.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Bodybody буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 820
