OnePlus 3 not responding
I recently replaced my OP3 battery after facing battery draining issues. Since then the phone has not turned on. The power button+volume down is also not working. But when I try switching it on with the charger plugged in, the OnePlus logo splash screen appears for a while and it switches off again. I can’t figure out what the problem really is. Need help ASAP.
Это хороший вопрос?
Счет 0
1 Комментарий:
Look carefully if you forgot to connect some cables or un-plug and re-plug connectors inside the phone.
из Поделиться
Добавить комментарий
