RCX 1.0 — это первая модель в линейке программируемых блоков Lego Mindstorms RCX.
How to fix RCX 1.0 I.R. problem?
The LEGO RCX 1.0 powers ON and all built-in programs work well. But when I tried downloading or even communicating with the I.R. Tower, the RCX wont respond! =(
Which component should be replaced or re-soldered? Please anyone... help pls. I just need to know.. which hardware component is at fault... so I can fix it.
Thank you =)
Это хороший вопрос?
Счет 1
3 Комментариев
hello, i have the same problem like sirgilberts.
My RCX 2.0 shows a icon for IR detection and my older RXC 1.0 doesnt react - i have three of them but they wont work.
из
I'm working in a Schoolboard and i have 6 RCX 1.0 bricks with the same problem. I am interested if someone finds a solution.
из
The main problem is that Windows does not recognize the IR tower. This happens with versions newer than XP.
из
Добавить комментарий
1 ответ
Выбранное решение
http://www.squidoo.com/collected-info-on...
it sounds like it may be a software problem, make sure you're up to date with any drivers for your console
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
also take a look on here http://messageboards.lego.com/en-US/show... for some more ideas.
из
Добавьте свой ответ
sirgilberts буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 26
За всё время: 3,193
