Where is the write protect screw
Anyone know where the write protect screw is?
Это хороший вопрос?
Это хороший вопрос?
Young aspiring engineer - i have two images attached that will show you what your looking for. Apologies on the quality of the images I’m 55 and a little cranky. This system belongs to a friend of mine and believe his son may of got carried away with the handling of the motherboard
. Time for a little repair. Careful with adding another OS onto Chromebook, referencing Windows primarily. A linux distro would be my choice due to its light weight nature. These are just suggestions, not an expert but like to bring things back to life. ciao
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 26
За все время: 2,198
2 Комментариев
Hi Waseem Azma
Suggest you to follow the guide and teardown to the mainboard section
Замена материнской платы HP Chromebook 14-ca061dx
Im not sure .. but if you observe on step 13.... there is a missing screw at the bottom right of it. check and compare with yours.
из Augustine Поделиться
out screw protector
из Jirole Tade Поделиться
