HP G71 — это серия ноутбуков производства HP. Ноутбуки G71 можно определить по номеру модели G71-XXX-XX; окончания номера зависят от комплектации и продавца.
Why don't my USB ports work?
I've noticed recently that both of the USB ports on the right side of my G71 are not working correctly. Whenever I plug a device into the top one, I get a "USB device not recognized" message, and plugging something into the other gets nothing at all. The third USB port (on the left side) works perfectly fine.
Это хороший вопрос?
Счет 2
2 Комментариев
Try reloading the USB drivers. Cheapest easiest fixes first then dive in to innards.
из
my cd roma worked until I update my window
из
Добавить комментарий
2 Ответов
Выбранное решение
I finally opened the computer. The ribbon cable from the USB board to the motherboard was unplugged at the motherboard. I now have all 3 USB ports functioning again!
Был ли этот ответ полезен?
Счет 4
I would remove the keyboard and check to see the connector for the USB ports on that side is firmly connected. If it is check the ports carefully for damage or debris. I am including a link the the service manual. Good luck.
h10032.www1.hp.com/ctg/Manual/c01713747.pdf
Счет 3
2 Комментариев:
Thanks for the link, I'll be sure to try that.
из
Definitely appreciate the link. Thanks for your help in this.
из
Добавьте свой ответ
David Hodson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 3,681
