Модель A1297 с цельным корпусом: начало 2009, середина 2009, середина 2010, начало 2011 и конец 2011 года
Metallic taste from surface of laptop
There is a curious metallic taste coming from the track pad and surface area of my mac book pro.
Has anybody encountered this situation ?
Это хороший вопрос?
Счет 2
4 Комментариев
happen with any other equipment? ever thought it could be your electrolytes?
из
what was wrong with the answer you received yesterday to this same question? Mayer knows his bickies and I think he has a very valid answer.
из
Don't lick your laptop
из
I m having a similar problem. Even when using imacs I feel a pinching feeling like pepper in my nose, lips and Metallica taste
из
Добавить комментарий
4 Ответов
Выбранное решение
Have your dentist replace your silver amalgam fillings with a composite material. Your metalic taste is most likely being caused by the slight electrical current discharging in your mouth via your fillings. Read up on it here: http://www.drpgilbert.com/metallic-taste...
Был ли этот ответ полезен?
Счет 20
5 Комментариев:
Didn't know this was possible. +
из
I was thinking similar lines re small current/electrolyte problem but more localised, it's a good read.
из
+ Hah! I had no idea this was possible. Crazy stuff.
из
Did you find the answer to your problem?
из
Early in my life I had a dental laboratory and did crown and bridge work, went to lab school for two years.
из
Этот ответ изначально был на другой вопрос.
I don't think it's normal to experience tasting flavors from simply touching an object.
That said, if you are touching an aluminum case and you lick your fingers afterwards, it's possible that you could be licking up some aluminum dust.
Either way, I wouldn't recommend licking your fingers or your laptop.
Счет 5
1 Комментарий:
My dog does that for me ;-}
из
I would try adding a colloidal minerals supplement in the liquid form to your diet to see if this resolves any mineral deficiencies you may have. Many of the minerals are metals. In chemistry the Theory of Equallibrium tells us that all touching matter exchanges atoms. I would also try washing your hands prior to touching the track pad. Colloidal/Ionized minerals are in the form of salts. Your sweat has salt in it.
Look to see if touching other items brings this sensation. That may help you narrow down the cause of it.
Счет 3
3 Комментариев:
that's what I was thinking.. you put it much better than i could.
из
I think if you had elaborated on your thoughts Poly that your words would have been more eloquent than mine. However no one seems to view our thoughts as a viable solution to the problem at hand.
из
ha ha..at hand! get it? ah well no one else will either. ;-P
из
sometimes, when i move myfingers over the metal part of my laptop, both the unibody and the one before, i feel some ‘stick-slip’. it is gone when i unplug the power. clearly, some voltage comes through.
Счет 1
Добавьте свой ответ
Michael буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 16
За все время: 2,577
