Руководства по ремонту и разборке принтера Epson. Компания была основана в 1942 году как Daiwa Kogyo, Ltd., но в 1959 году объединилась с другой компанией и создала Suwa Seikosha Co., Ltd.
error light paper blinking
Hi,
My epson printer L3110 having light paper blinking but already check all is good. No paper jammed or any object inside the paper slot. I check with system show : MEMORY CARD IS LOADING ERROR
so what should I do to get the printer is normal? And what the solution to solve this error.
This is new printer as i buy last month.
Hope can help and run as normal.
thank you
Rafi Haron
Это хороший вопрос?
Счет 7
Добавить комментарий
6 Ответов
Наиболее полезный ответ
Knowing the model number is always helpful.
This can sometimes revive epson printers that are being difficult…
https://epson.com/support/updating-your-...
Был ли этот ответ полезен?
Счет 1
The way to solve this problem is quite easy if you want to follow the procedure I explained like this, open explores -> this PC -> Manage -> device manager -> print -> update driver.
After the driver is updated, if it doesn't work, just uninstall the driver then download it again by clicking via the link below:
download driver epson l3110
Счет 1
i know ,that probel will make you job disturb, i want to give suggestion you can find theright driver for your printer driver. I know but it is for model epson l1110 may be next time i will find good driver source for your epson l3110
Счет 0
Rafiharon bom dia,
deve ser algum sensor q esta com problema em sua impressora, e por isso acusa o erro de papel, verifique tambem se pode ser a mola do sensor de papel, pode ter escapado.
Счет 0
katika epson l3110 taa ya ink na taa ya paper zinawaka pamoja nini suluhisho
Счет 0
Boliye is ka solution
Счет 0
Добавьте свой ответ
Rafiharon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 27
За все время: 4,483
