Where to get replacement screws?
While replacing the thermal paste, I accidentally stripped one of the screws for the motherboard. I know that this is a relatively newer model, but where might I be able to find replacement screws?
Это хороший вопрос?
Счет 0
2 Комментариев:
To be able to help you, we need to know what screw you need to replace.
из
Why did you replace the thermal paste on such a new system?
Yes, Apple doesn't use the best of paste but it still shouldn't need to be replaced in less than a year. You also put your system at risk as Apple now has a reason to deny you warranty coverage. It's always best to wait until the warranty coverage has ended before you alter things.
Post a picture of the bottom cover marking off which screws are missing Добавление изображений к существующему вопросу
из
Добавить комментарий
