Procedure to change the default application
Microsoft Excel happens to be my default application, I need the procedure to change it from numbers. Please guide me.
Thank you
Narayanan Lakshmanan India
Это хороший вопрос?
Thank you
Это хороший вопрос?
Click on a spreadsheet document, goto the menu File then slide down to Get Info your files info pane should be open twist the twisty Open with: There you can alter the application to use in this case MS Excel to alter all spreadsheets click on the Change All button
Был ли этот ответ полезен?
I am unable to understand the twist the twisty Open with.I am unable proceed further.Please clarify.
Thank you Naryanan lakshmanan India
Click on the small triangle that's called a twisty as when you click on it more information is shown user that heading.
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 9
За всё время: 287
