The OnePlus 6T is an Android smartphone made by OnePlus. It was announced on October 29, 2018 and released on November 6, 2018.
26вопросов Показать все
I Accidentally scraped my battery
I accidentally scraped my phone battery a couple of times while removing the back panel of my OnePlus 6T. Should I replace the battery or will this battery still work like this? It is not punctured at all, just has some grooves on top
Это хороший вопрос?
Оценка 0
2 Комментариев
You should never use damaged batteries but you can add a picture of it so we can see how damaged it is.
Adding images to an existing question
из
Picture added to the question. If I may add, I have already charged and gone through 3 cycle charges and the battery does not overheat or anything. Would this still be considered heavily/dangerously damaged?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Even if it works fine, replace it. Normally I wouldn’t be concerned about a very, very light surface scratch but these are deep enough to warrant replacing it. Softcells have zero protection like old modular ones in a metal case.
It may be fine, but it’s not worth the risk since softcells are so easy to damage. The battery can be found here.
OnePlus 6T and 7 Battery Изображение
Продукт
$14.99
Был ли этот ответ полезен?
Оценка 1
Never used damaged batteries in devices, especially if you get the smell of rubbing alcohol or burnt skittles as other people have described it.
Оценка 0
2 Комментариев:
I just added a picture To my question. No smell is coming out of it. I'm just worried if those grooves may be considered dangerously damaged or not. Can I please get your feedback on it?
из
Yeah I'm concerned about those grooves. I would get a replacement, it's not worth the potential third degree burns.
из
Добавьте свой ответ
Alberto будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 335
