Модель: Dell Vostro 1440/1450/1540/1550 Дата выпуска: 2009
How to solve laptop hang issue?
I face difficulty due to laptop hanging while working from home. Provide me a solution to speed up my laptop.
Thanks in advance!!
Это хороший вопрос?
Счет 0
1 Комментарий
Hi John,
There are literally hundreds of possible causes.
We will try to answer your question if you give us more details.
We are not clairvoants!
Like what operating system are you using?
What program or programs are you using when it happens?
Is it overheating?
Etc., etc. etc.
Regards,
Mike
из
Добавить комментарий
1 ответ
Выбранное решение
Hangs have varied causes and symptoms, including software or hardware defects, such as an infinite loop or long-running uninterruptible computation, resource exhaustion (thrashing), under-performing hardware (throttling), external events such as a slow computer network, misconfiguration, and compatibility problems.
To solve the problem, check out posts and troubleshoot by yourself:
https://www.minitool.com/data-recovery/c...
https://www.minitool.com/partition-disk/...
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Thanks for your kind solutions, I will check out it. If you want to write an article about this problem we are happy to publish your blog on site: http://techidology.com/
из
@johnpeter07 Thank you very much, will let you know if there's any interest.
из
Добавьте свой ответ
john peter буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 28
За все время: 682
