Nokia 6030 — это двухдиапазонный GSM-телефон с автоматическим переключением между частотами.
How to repair power button?
The Nokia 6030 has its power button on its top as part of the back casing.
I have noticed that the button does seem to work/respond very well anymore on a unit. My impression is that its alignment with the contact it presses into may not be correct. Perhaps the button is somewhat warped.
It looks like the button may be removable, but I have not been able to remove the button with decent pressure from under where it appears to be attached.
How can one repair the power button? Can the repair be done without replacement of the back casing itself?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Nokia 6030c-2 many bottom not working problem
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Nokia mobile 6030c-2 many boton not working problem
из
Добавьте свой ответ
User5 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 20
За всё время: 382
