Основная модель линейки смартфонов 2019 года от Apple, выпущенная 20 сентября и получившая название iPhone 11. Устройство получило 6,1-дюймовый дисплей с двойной камерой и в шести цветах. Достойный преемник iPhone XR.
475вопросов Показать все
Should FaceID work when LCD opened?
I’ve purchased iPhone 11 with cracked display - FaceID not working - sometimes showing “not available” but many times just “move higher, lower - closer iPhone message” which I think confirms it is kid-of-working.
100% crack was on cameras and whe worse half crack opened on that “mirror” thing which is in my opinion that projector - but not sure.
I just wanted to know if I should be able to test FaceID when screen opened so no cracked glass on the way.
There is something mirror on that area on display where ‘Projector’ present.
I don’t want to spend £80 on display if FaceID not working :(
I’ve tried with opened screen to activate FaceID but no success as not easy to point directly on face what cannot see what is happening on display - but normally it should even start doing scanning.
Thank You
Update (09/24/2020)
As I’ve learned from this video - “dot projector” is not cracked and “Flood illuminator” is fine - no signs of water damage
Why Face ID Not Working After Repair
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
If there are any cracks in front of the sensors it can diffuse the light and cause errors. You won’t necessarily know if you can fix the issue unless you at least inspect the assembly for any damages. I know that screen can be a little pricey but even if you can’t get FaceID to work, I would imagine you got a great deal on an iPhone 11.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Bart будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 30
