Bottom Case Screw Size
Hello,
I need replacement screws for the back casing of my Asus X555L-LA; I found a guide that gives the screws in MM here: Замена жесткого диска Asus X555LA-SI305041
The two screws references are:
  • Six 9 mm screws
  • Four 11 mm screws
but what would they equate to with the replacement screws that I have pictured below?:
Это хороший вопрос?
Счет 0
1 Комментарий:
What does bottom case screws have to do with hard drive caddy screws?
It makes no sense the question you are asking.
из
Добавить комментарий
