Робот-пылесос Samsung с поддержкой Wi-Fi. Номер модели: VR2AM7070WS/AA.
Vacuum Motor upgrade help
Hi. I have a very important question. Samsung powerbot vr7040 has 10w motor, can I replace this motor with 20w motor used in other models like vr7065 vr7070? Is there a problem with the electronic circuit? What kind of work should I do? I would be very happy if you could answer. Thanks.
Это хороший вопрос?
Счет 0
1 Комментарий:
Hulusi Şen wondering why you would want to do that
из
Добавить комментарий
1 ответ
The motor wouldn’t work, because the 20W motor would try and draw 20W from a 10W connection and circuitry, which would shut down the PowerBot or fry the circuits. I’d heavily recommend looking for the proper part.
Not sure where’d you’d find the part, but good luck!
Замена мотора пылесоса Samsung POWERbot R7070
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
I understood. I got the answer I was looking for. thank you very much.
из
Добавьте свой ответ
Hulusi Şen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 346
