THINKPAD T520: первоклассная производительность и портативность.
Computer is on but screen black?
My laptop worked yesterday. Today I attempted to turn it on as usual, pressing the power button. It made all the usual noises. On startup, It makes a beeping noise, but that is normal. Today the screen is completely black. I can tell it’s on. The fans are running and the light is on. Still, the screen is black.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
DiamondWolf Gaming  connect an external monitor. If that works you know the issue is with your display. If it does not then it could be a GPU (motherboard) issue. Also while your computer is on, in a darkened room, shine a flashlight beam at an angle against the screen. See if you can make out your menu etc. If so you know it is a backlight issue.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
DiamondWolf Gaming буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 627
