Hard Drive and Memory Upgrade
Can the hard drive and memory be upgraded in the Mac Mini with the M1 chip?
Это хороший вопрос?
Это хороший вопрос?
Был ли этот ответ полезен?
Soldered AND glued up, way to go Apple!
As an ex Apple aficiconado, I am sorry to see Apple choose this path. It was hard enough with the high prices, but this is the icing on the cake. Market share armageddon.
The 2012 mac mini was a marvel of engineering. Almost as if Apple said... "we can make a machine that will last forever" AND "you can modify it in all kinds of ways- you've got choices."
Last 5-10 years has been the dark ages of Apple products tho'. Do they do any kind of design reviews on their boards in the post-Jobs era? I really wonder about that... their products seem like 'amateur hour'
Thank you for showing us that photo. Helped me decide not to buy- my kid can run Linux instead.
There's a video on YouTube by Luke Miani; Upgrading an M1 Mac mini SSD from 256GB to 2TB. Only for the brave ones, you have to know what you're doing.
As the trend goes with Apple products, all “smart” parts are serial-paired and possibly encrypted. Swapping original parts may not work, not to mention trying to replace it with aftermarket parts.
Upgrading storage on iPhones are possible, but involves high-skill soldering and pre-programming. Could be the same story for M1 Macs, but I usually don’t have high hopes for this.
This is a picture of decaying capitalism, money, money, money and in return nothing, greed
I wouldn't call it "nothing in return". For quite reasonable money, you get a lot of quiet performance. What to complain about?
I have the Late 2012 quad-core i7 version of the Mini and know how great those machines keep working thru the years.
Bought recently the M1 equivalent and couldn't be happier. With Thunderbolt connections you can easily live with it - even if you do a lot of video work - as I do.
Apple didn't hide the fact that you cant do any more upgrades.
The first Mac Minis allowed a CPU upgrade (if you were brave enough) as well as RAM, disk and optical drive. Obviously you could only put in what the motherboard supported, but it was a step in the right direction. Even the 2012 model is okay, I've got mine up to 16GB RAM and two hard drives totalling 1.5TB, the latter using the guides on this very site.
For me, the killer decision to not by an M1 Mac Mini, along with the non-upgradable disk and RAM (meaning I cannot buy the base model now and upgrade on the cheap in 6 months) is this : https://discussions.apple.com/thread/252...
Did you open a bug report with Apple on Logic Pro? I'm sure the other M1 based systems suffer the same fate.
What Ritchie Swann said sounds like I wrote it! I mistook it for my writing! I have exactly the same experience and am probably going to move completely over to Linux instead of the M1.
Mostly because of the upgradability issues + as a result of what Louis Rossman has said (more or less) about Apple having learned to be incompetent at hardware design, since the 2012 timeframe, when they were still making really great machines (example 2012 Mac mini and 2008-2012 Mac Pro models, which are also excellent).
@danj A bug report has been filed with Apple because of that thread. As I've said elsewhere, I'm amazed that a new machine that has been heavily advertised as the best to work with has a crashing bug.
@Ritchie Swann - Did you second it? Or add your own report. The squeaky wheel gets the grease!
Wow, looks like a Raspberry PI design ;)
@maltacode The principal difference is a Raspberry Pi is cheap and easily replaceable. If a Mac Mini cost $35 and the logic board could be accessed via four Phillips screws, nobody would complain about this.
@Ritchie Swann I was merely talking about the all-in-one design of motherboards, not comparing anything else, as that would be totally useless.
Well for $39 I guess the new Mac Mini would be worth the hassle.
I replied yes on the question for upgrading the hard drive on the mac mini...i stand corrected. Ive got the A2348 and took it apart, no on the hard drive for me. Fan, memory, um, remove dust what be as far as I go. Laptops, yes and blindfolded:) okay maybe not blindfolded, friday humor-
Which model is this? So yes you can upgrade ram?
@Leslee Langlands On the 2018 mac Mini model, yes. At least for RAM. On the 2020 M1 (which I believe is referenced here with the A2348 model number) and recently released M2 models, nope. Everything is soldered straight to the logic board.
За последние 24 часов: 8
За последние 7 дней: 43
За последние 30 дней: 220
За все время: 38,221
1 Комментарий
Here’s a bit more detail including a link to a teardown video: https://www.macrumors.com/2020/11/18/app...
из Brad Miller Поделиться
