PS5 отличается значительно улучшенными характеристиками и новым инновационным контроллером Dualsense. Черно-белая цветовая гамма в стиле космической эры заметно отличается от дизайнов PlayStation прошлых лет. Выпущена 12 ноября 2020 года в США, Канаде, Мексике, Японии, Южной Корее, Австралии и Новой Зеландии, и 19 ноября по всему миру.
DualSense Ribbon-Cable: Can I replace it?
Hello guys,
unfortunately i need to replace one of the ribbon-cables in the Dualsense-Controller. Its the one that connects the Vibration motors wirh the mainboard. Any Idea if i can use a different one? Or is this some special Sony thing?
Thanks in advance!
Best Regards
Andreas
Это хороший вопрос?
Счет 5
Добавить комментарий
3 Ответов
Наиболее полезный ответ
I had to replace mine too, I was able to use a 16-pin 0.5mm ribbon cable (this would be 8.5mm wide) that was from an old laptop display until i could get a new one. You will need to be careful though, I tried some I ordered online and it didn’t even power on. I think the laptop one worked because it’s a directional cable and specified which end should go to the motherboard and monitor (or in this case the trigger assembly).
Edit: For the ribbon cable I ordered I believe it was A type, but I think B type would be more likely to work.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
I ripped my L2/L1 Ribbon cable on my ps5 controller during disassembly. anyway i can buy a new cable and what size is it? Or is it repairable. the cable is sheared in half.
из
If you search for a 16-pin 0.5mm B type cable on amazon or newegg it should come up. Here is one you can try: https://www.amazon.com/dp/B07S1BNYTS/ref...
I haven't tested this one but if it can be used to carry a laptop display it should work for the trigger assembly. You may have to fold it a bit to fit in the controller. If it doesn't work i'd suggest looking for a cable with higher tolerances (i.e. max voltage, ampage, etc.), b-type, and 16 pins at 8.5mm wide.
из
Yeah those are extremly hard do find, Found a guy in Germany selling them
Счет 1
Hi Andreas , I had the same problem, then I found these guys in the Netherlands.
https://xqgaming.com/en/563-repair-parts
Счет 1
3 Комментариев:
recently I got some from these guys in China. I got them in 10 days.
https://www.aliexpress.com/item/10050030...
из
Does this company have a good reputation? Do they sell a ribbon cable for the PS5 controller touchpad? I have tried to find one on Amazon but am unsure which one is correct.
из
Since Andreas's post in 2020 these parts are more widely available now; and you can find them now on eBay and Amazon.
из
Добавьте свой ответ
Ace100ace200 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 50
За всё время: 6,916
