Выпущенная в феврале 2014 года колонка Bose SoundLink III представляет собой третье поколение мобильных динамиков Bose SoundLink. Это современная, минималистичная портативная Bluetooth-колонка.
Bose speaker not charging
My bose portable speaker is not starting after its battery reduced last night.
I hv tried changing cables also(Type C) still its not starting.
please suggest
Это хороший вопрос?
Счет 1
1 Комментарий
I've got a powercolor 2. The battery ran completely out, and now it will not take a charge or turn on (no lights turn on).
If I plug it into the computer, the computer will detect it and "set it up", however, when I try to run the Bose updater, it fails because the speakers won't communicate with the computer.
There is a popular solution if you search for it - keeping the power button pressed while plugging it into a computer and then unplugging it and letting go, then plugging it back in and pressing the power again, but this does not work for me.
I used them recently and they worked for a number of hours without a charge, so I think the battery is fine, and a quick search online shows this is not an uncommon problem for these speakers. Just want to know what to try next.
Thank you in advance!
из
Добавить комментарий
1 ответ
Выбранное решение
hariom gangwar  not quite sure what you mean by this “battery reduced “ but I’ll assume you mean the battery went down and did not longer work. Since you already tried a different cable I suggest that you change the battery. IF nothing else it will provide you with a known-well starting point for further troubleshooting. Let us know which Bose speaker this is so we can try and help you further if needed.
Был ли этот ответ полезен?
Счет 1
6 Комментариев:
It is recently released bose portable speaker bought 1 months back.
Its battery was low last to last night approx 1-2 % and we left it for changing at night.next day onwards its not starting
из
@hariom gangwar since this is only 1 month old, return it and have them fix it under warranty. After all, you paid for that.
из
Mine is out of warranty. It’s not been charged for a couple years due to moving. What do I do?
из
It is a Bose sound link Bluetooth speaker ||| or 3
из
I’ve had it on the charger for over an hour I still have no light coming on. I understand it needs to be charged extensively but if you could tell me how long before I might see a power light emerge?
из
Показать ещё 1 комментарий
Добавьте свой ответ
hariom gangwar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 17
За последние 30 дней: 42
За все время: 3,067
