Google Pixelbook Go — это премиальный хромбук от Google, выполненный в прочном магниевом корпусе с минималистичным дизайном. Выпущен в 2019 году. Номер модели: GA00521-US.
Re-insert clamshell pin into hinge
One end of the hinge on the Google Pixelbook Go has slipped out of place. I do not know how to reinsert it. The two pieces of the clamshell do not feel flexible enough to bend and allow the pin to slip back into the hinge.
Это хороший вопрос?
Счет 4
Добавить комментарий
4 Ответов
Curious what you ended up doing here. Your issue (and mine) is that the hinge itself is broken. This is caused my the screws loosening causing a torsional flex in the hinge when then snaps it.
The screws loosen over time due to hinges being too tight.
Google isn’t supporting the devices and there’s no way to get replacement parts.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
TL;DR Don't buy Pixelbooks.
I returned the broken Pixelbook to the seller and got back 80% of the purchase price. The money I got back was enough to buy two Lenovo Chromebooks w/ 8GB and touch screens.
из Поделиться
I have the same Pixelbook AND the exact same issue. I have another problem as well, when the right hinge is lowered, the display goes black, everything still works, the device isn't turned off, I believe it might be a severed display cable
из Поделиться
It seems that the hinge is snapped from the image. Could have happened when the LCD is accidentally pushed exceeding the limit. Can be fixed by removing the back cover and swap out the damaged hinge.
Счет 0
I was able to buy a hinge on eBay (at outrageous price for such a small element) and replace it, otherwise you can replace the whole unit for $$$.
Счет 0
@piotrkaminsk163 How did you replace it?
Счет 0
Добавьте свой ответ
Aaron Hoffer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 20
За все время: 1,633
