Dell Latitude E5550 — это 15-дюймовый бизнес-ноутбук. Он был впервые выпущен в конце 2014 года с процессором Intel 4-го поколения, а затем обновлен в начале 2015 года с процессором Intel 5-го поколения.
New battery is bad?
Just installed a new battery into my laptop and the battery indicator is flashing orange.. the bios screen says “battery not present”. Laptop does boot the laptop but it won’t charge. tried multiple power adapters.
Это хороший вопрос?
Счет 3
5 Комментариев
Once booted up, down on the right side of the TaskBar, what does it say about the battery ? Any charge?
из
It says idle or not charging. depending on where you look.. I also put it into another laptop and have the same response.
из
@Jon Mroz
Does it show any percentage of charge?
из
@Jon Mroz
So it shows 38% but does it indicate any charging or just a static 38% ?
из
Добавить комментарий
3 Ответов
Выбранное решение
OK this has been solved..
When the replacement battery came in also not able to communicate i suspected a change in the firmware..
This laptop was on the latest A24 so i downgraded it to A14. Now it works.
It seems that firmware Latitude E5550 A22 is when they changed the charging circuit routine and broke the ability to charge aftermarket batteries.. I suspect this is happening to any dell laptop.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
hey. also have a dell latitude e5550, but it doesn't turn on without the charger. ¿How do I know what firmwere do I have?
из
If same result in another laptop then the battery is probably defective.
Is it a DELL battery or a third party one?
Update (01/16/2021)
How to Reset the Dell Battery Sensor
You can follow the following steps, which take only minutes and require no tools, to attempt a reset of your Dell battery:
  1. Completely power down the laptop and remove the cord from the computer.
  2. Flip the laptop over.
  3. Push on the battery release button or buttons to release the battery form the computer and remove the battery.
  4. Power on the computer without the battery, allowing it to boot completely.
  5. Completely power the computer down and remove the cord once again.
  6. Reinstall the battery, plug in the power adapter and re-boot the computer.
Let us know how it goes.
Счет 1
4 Комментариев:
It is a iFixit replacement battery.
из
This did not work.
Dell laptop and I recently had a new ac adapter installed.
still says "255% available and plugged in"
из
I too have same message after installing new battery. Any resolution would be helpful
из
Same issue here. Inspiron 3521. Original OEM battery was giving me this error. I just bought a new Dell branded battery on eBay (looks identical to me in every way, but for $25 could be a fake), and getting the same error. I am trying some things such as Windows update, Dell updates, chipset update. Bios says version A12. Ironically, Bios version A16 wouldn’t install without a recognized battery installed, ha. So far, I got it to at least show 255% battery remaining. Tried the reboot with battery removed. Still getting the message battery cannot be identified upon boot, and it immediately turns off when unplugged.
из
I ordered two new 87Wh for my DELL Latitude E 6430, but it's not charging. Battery LED indicator on laptop flashing 3 times amber and one times white.
Счет 0
Добавьте свой ответ
Jon Mroz буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 46
За всё время: 18,412
