Новейший телефон серии e от Moto по состоянию на 2020 год. Модель XT2052-6.
How do I replace my screen?
I have a Moto E 2020 and I cracked my screen. How do I take it apart and fix it?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
I'm in the same boat, and I'm here looking for the same help lol but I have a part coming and I'm going to test it out.
The bottom of the screen is the most significant part of it and you must be careful not to wedge anything too far under it for you might damage something. But from the looks of it, the plug to only worry about is actually towards the middle of the screen. There's a plug that goes into the board that leads to the bottom of the screen, but I can't determine whether it's reusable from the screen or not yet, but if it is it's connected to the bottom of the screen so watch out. I also assume that you should be very careful not to damage the camera and speaker up top.
Treat it like any other tutorial here; heat one of the sides and lift and prop it open, carefully and slowly slice away all of the surrounding adhesive. Treat it like there's plugs on each side until you can see better.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Hi @techcorrect ,
How about you create a guide whilst in the process of fixing your phone?
Others in the future will no doubt thank you.
Most of the guides on Ifixit are created by users, just like you.
Here's how Как создать руководство
Cheers
Moderator
из Поделиться
Yes, please do! I'm in the same boat, it Just sounds like I'm MUCH less experienced than you are. TY.
из Поделиться
Добавьте свой ответ
Hustin D. Hemphill буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 31
За все время: 698
