Minolta X-700 — пленочная камера, выпущенная компанией Minolta. Мы предлагаем информацию о том, как заменить аккумулятор, затвор, светоизоляцию и конденсатор.
How to fix stuck shutter and mirror?
I have this camera and today the shutter and mirror got stuck, tried to change batteries but nothing works. Please help!
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
try to pull the shutter cloth in the direction of the rewind knob. You have to put one finger through the mirror case and another from behind pulling the cloth in between of the both. Do this very gently. The shutter will click and the mirror will drop.
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
Thank you! That worked perfectly 😊
из
what if it after doing that and winding the advance lever, then taking a picture, the mirror goes up but the curtains don't move?
из
I just used this method and successfully fixed my X-300! It stucked up when it suddenly lost power during filming. Thank you so much! I searched for hours using AI but couldn't find this anywhere
из
@arborcerti97568 -
I have an XG-A and a X-700 in this stuck state (shutter button doesn't press, unable to advance the film lever. There is no film in either camera.
I assume that the lens must be removed in order to push the curtain from both front and back? Does someone have a picture of this process?
из
Добавьте свой ответ
Eduardo Capdeville буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 16
За последние 30 дней: 66
За всё время: 3,004
