Модель M5884 / процессор G4 с частотой 400 или 500 МГц
No power
Dear all,
my beloved PowerBook Titanium does not want to power up. Battery is ok as well as power supply. Any idea?
Это хороший вопрос?
Счет 3
1 Комментарий
Have the same problem. Tried resetting and still nothing.
из Поделиться
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Try looking here: http://support.apple.com/kb/HT1431#faq8
Resetting the PMU might do the trick. I know the ol' Titanium is sweet, but it also might be time to look at a newer model.
Был ли этот ответ полезен?
Счет 2
It could be your DC-in board. The best way to test it would be to slide in another battery that has a charge to it... if the computer turns on, it is most likely your DC-in board. You can purchase one here if you are interested:
http://www.ifixit.com/PowerBook-Parts/G4...
And you can look at the repair guide here:
Замена платы питания PowerBook G4 Titanium DVI
Счет 1
1 Комментарий:
Beware Tyler's solution does not apply to the Mercury Model. The Mercury doesn't have a separate DC-in board.
из Поделиться
Try taking out your PRAM battery, shown in the remove PMU guide (it's the big thing marked 616-0114-A)
Disconnect the tri color lead from that to the PMU, start up the PowerBook (it should now work), then reconnect that cable and hopefully you should be left with a functioning PowerBook !
Счет 1
2 Комментариев:
So, disassemble to step 16, disconnect the tri color lead, reassemble, turn on computer. Disassemble to step 16, reconnect tricolor lead, then reassemble? Is that correct? Why would this work?
из Поделиться
из Поделиться
Добавьте свой ответ
Emerenziano буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 12
За последние 30 дней: 42
За все время: 7,817
