Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
replacing screen adhesive strips
do you attach the 3M strips to the glass or case,
And is there a guide to the placement of each strip
Это хороший вопрос?
Счет 2
2 Комментариев
Replacing screen
из
martinezramon974 do you need help? if so please post a detailed Question on the question form
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
I had huge problems after replacement to fix the frontpanel well. Maybe because of this the gave me two sets of adhesive tape... So anyway better to use two layers of the 3M tape if available...
My final solution after bad sticking frontpanel was at the end to use silicone sealent... now it sticks perfect and works also as a good sealing for dust...
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
What kind of silicon sealant?
из
Here is the guide:
http://ipadscreenrepair.com/repair-guide...
Scroll down on the page for adhesive diagram.
Счет 2
here is the placement of the pre-cut 2 sided tape for ipad 2
[http://www.ipadscreenrepair.com/wp-conte...
it is very cheap and easy...
Счет 1
Добавьте свой ответ
Gary Kukulka буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 14
За всё время: 44,254
